Is the Behringer BCR2000 compatible as a midi CC controler for the LXR?
just this question:**
Is the Behringer BCR2000 compatible as a midi CC controler for the LXR?**
or is there any other controllers besides 60KNOBS and the one from the US (barcode?)?
or any easy to follow DIY guides, even?
  • probably , its quite capable of doing a lot of devices.
    start simply and go from there , setup a cc that you can easily/instantly hear that is working , e..g volume/pan/distortion.
    if the controller has midi out , and does midi cc , it'll probably work.
    i've been using ipad pro / midi designer pro via iconnect midi box into other midi devices with no issues. (meeblip , tb03 , digitakt )
