USA power supply recommendation? +Build into erica case?
I am anxiously awaiting my kit with trigger I/o and enclosure, in the meantime I want to make sure I choose the right power adapter so I can play with it as soon as I'm done building it. Does anyone have an amazon link for one that works?
Also, would I run into any issues if I don't use the lightpipes but rather solder the led's flush to the openings in the case?
  • I use a 7.5V switcher from Mouser.
    I solder the LEDs flush also, make sure you ream out the holes so the LEDs fit
