LXR Trigger IO - Triggers work great, Clock IO does not, any advice?
So I just built an LXR with the trigger IO expansion. The LXR seems to work great and even the Track trigger gates work as expected but for some reason it does not seem to send or receive clock1/2 IO at all. I am curious if there is a particular setting I need to adjust or if anyone else is experiencing this issue. Any help is appreciated.
  • edited October 25
    My clock 1/2 is working fine.
    I use it to send a clock to my analog sequencer.
    Have you soldered in the little wire bridges?
    Have you select a speed divider?
  • Thank you so much, it looks like i missed some of the bridges!
