LXR worked for 5 min
I had issues running the unit and after double checking soldiers found one switch missing two contacts. After connecting and going over any less than perfect soldiers I had the unit running outside of the case for almost 5 minutes. after assembling the case I have no operation. taking the case off did not solve my problem. buttons are unresponsive and there is no scolling. Only OSC. and REC lights are on.
  • This sounds like an unstable soldering point, which cracked after assembling.
    Try to look, if the case is pressing on the pcb somewehere and try to resolder all points, you soldered before. I hope it helps!
