LXR 4th encoder issues
4th encoder from the left is scrolling in parallel with 3rd encoder.
The values on the screen doesn't change when turning the 4th encoder, but it follows the value of the 3rd.The only way to change the 4th value on the screen is to use the main knob to the right of it. What could be the problem? Have I shorted something?
  • I've had the same problem as some people here have talked about, the 4th pot was "noisy" and wobbled between two values, e.g 64-63.
    I re-solder that particular pot and it seemed that this issue was solved. But now, when I finally came around to putting it in a case, the 3rd and 4th pot is only tracking the 3rd pots value.
    pls help !
