lxr error display
  • Hello good, I turn on my lxr and put a message kit read error not detected the tension is ok someone can help me? thank you very much
  • do you have a SD card in the slot and also at least one preset on it?
    The error message means the LXR can't read the initial preset file from the SD card.
  • Hello again and it sounds but I turn it on and when pulse start does not run and then no longer let me change the pattern, thanks in advance I do not know what happens
Howdy, Stranger!
In this Discussion
